14 years agoCyclone III PLL loses lock at >75C
I am using PLL reconfiguration. When the FPGA is powered up the PLL is loaded with different M, N and C values for the frequency I want to generate. The PLL will lock below 75C but once it gets t...
14 years ago75C measured using thermocouple on the part.
Input clk is oscillator quality is good, voltage regulator is OK, switching noise is hard to eliminate, I have reduced outputs to minimum current. Those were my thoughts too, thanks for the replies.
