Vic3Dexe
4 years agoCyclone III multi-device AS problem
I have two identical EP3C16Q240C8N in multi-device AS scheme.
First, I've soldered master and EPCS16 and checked it is accessible through JTAG and AS.
It was fine, so I've soldered slave device, ...
- 4 years ago
Problem solved.
I'm very embarassed.
You (of course) need to assign nCEO at master as programming pin.
I'm really don't know how did it turn out as regular i/o.
Sorry to bother you.
Vic3Dexe
4 years agoThe problem: they both don't load from EPCS.
All user i/o pins at both devices at Vccio - 0.2V (Vccio = 3.4, all pins has about 3.22).
Master nCEO = slave nCE = 3.4V (pullup 10k to 3.3 rail).
CONF_DONE = 0.
nCONFIG = 3.4V.
nSTATUS = 3.4V.
Just rechecked slave connections - all ground/power/program pins soldered correctly.
And again - signle master worked correctly.
