16 years agoCyclone III, huge cap at VCCD_PLL
Hi All! Altera document "Cyclone® III Device Family Pin Connection Guidelines PCG-01003-1.0" says that 470 uF capacitor must be used at digital power of PLL (besides a lot of ceramic capacitor...
16 years agoI think that the reason is real. PDN consists of several ceramic capacitors and its own resonanses are far from inductive component of bead impedance, so LC oscillation tank[s] takes place in any case. What do you propose to prevent negative influence of the parasitic resonances? IMHO, the using of large bulk capacitor is good enough solution.
