17 years agoCyclone III EPCS16 config FAIL
Hi all, I'm working on a revision of a PCB that contains a total of 12 EP3C16Q240C8N all configured with the same object file as in figure 10-6 of the datasheet. As it stands now, the configur...
16 years ago --- Quote Start --- I have verified that our config problem was caused by a buffer with bus hold circuitry. We disconnected the buffer and the config lines were pulled up normally. We will switch to a buffer without bus hold circuitry. --- Quote End --- Hi phil: Servral questions: 1, Are there 2 devices in your system? if so, is it necessary to add buffer? 2, After you disconnecting the buffer, were the config-done and nstatus pull-uped by 10k? or 4.7k?
