17 years agoCyclone III EPCS16 config FAIL
Hi all, I'm working on a revision of a PCB that contains a total of 12 EP3C16Q240C8N all configured with the same object file as in figure 10-6 of the datasheet. As it stands now, the configur...
17 years ago --- Quote Start --- I think the problem is being caused by a buffer that is connected to the lines. There is a std 74lvth244 buffer that both signals are connected to. I think the bus hold circuitry is latching the inputs low on power on. I am going to replace the buffers with a non-bus hold type and see if it fixes my problem. Phil --- Quote End --- I have verified that our config problem was caused by a buffer with bus hold circuitry. We disconnected the buffer and the config lines were pulled up normally. We will switch to a buffer without bus hold circuitry.
