17 years agoCyclone III EPCS16 config FAIL
Hi all, I'm working on a revision of a PCB that contains a total of 12 EP3C16Q240C8N all configured with the same object file as in figure 10-6 of the datasheet. As it stands now, the configur...
17 years agoRandom thought, you didn't tie all of your conf_dun pins together and also put a 10k pull-up on each one did you? Or something similar on the nStatus pin?
