18 years agocyclone III development kit + flash memory
I have purchased the Altera cyclone IIII development kit . I have loaded my design onto the flash memory, so when I power the board the FPGA is configured with my code. Is it possible now to use the ...
18 years agoWhat you wish to do is very do-able.
Do you only wish to read the extra data in there, or do ou widh to be able tyo have your design write it, then read it? Look as the ASMI MegaWizard for a port that will allow reading / writing into the extra space in the Flash (assuming you are talking about the serial EPCS flash). Press on, then advise if you need more help.
