14 years agoCyclone III configuration corrupts image
All, We have 30 boards with a single EP3c25 wired for JTAG and AS configuration, as per the handbook. Several pairs of eyes have peered at the schematic and the boards and everything looks like...
14 years ago --- Quote Start --- How would I synchronize a reset? --- Quote End --- Reset signals from a push-button, external reset supervisor, or from the USB-Blaster interface are asynchronous signals. The reset inputs on the registers within an FPGA have a setup and hold time (called the reset recovery and removal time). If you violate this, then weird things happen. You synchronize the external reset to each clock domain by running the signal through a reset synchronizer circuit. Altera has examples. Cliff Cummings of Sunburst design also has several good papers which discuss the topic. --- Quote Start --- I seems to me that all that is handled by the USB Blaster. --- Quote End --- Nope. If you're using it to program the FPGA, that's all it does. --- Quote Start --- Second, i had the same idea, but to use signal tap requires that I am able to configure a bad board, which is what I can't do. --- Quote End --- Perhaps you can program the image into the boot device and then try connecting? Cheers, Dave
