14 years agoCyclone III configuration corrupts image
All, We have 30 boards with a single EP3c25 wired for JTAG and AS configuration, as per the handbook. Several pairs of eyes have peered at the schematic and the boards and everything looks like...
14 years ago --- Quote Start --- I've checked. INIT_DONE toggles and goes high at the end, as it's supposed to. --- Quote End --- It sounds like the FPGA likes what it is receiving then. Did you put any thought into FvM's suggestion - have you synchronized the reset to the clock domains within the FPGA? Have you checked your PLLs are locking ok? I'd recommend putting a SignalTap II instance into the design. Then download and let Quartus communicate with the instance. If it can communicate, then you have a design error. If Quartus cannot communicate, then there must be some form of corruption - however its a strange one, since nSTATUS would normally go low in that case. Cheers, Dave
