14 years agoCyclone III configuration corrupts image
All, We have 30 boards with a single EP3c25 wired for JTAG and AS configuration, as per the handbook. Several pairs of eyes have peered at the schematic and the boards and everything looks like...
14 years agoCan you probe the INIT_DONE signal?
Look at p56 (these are for PS/FPP, but the signals should do the same thing for JTAG configuration): http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/fpga_configuration.pdf) Note how INIT_DONE goes low when programming starts, and then high again when done on p60. Note how there is a delay between CONF_DONE and INIT_DONE. I wonder if your FPGA is being left in the no-mans land between CONF_DONE going high and INIT_DONE going high. See p63 for enabling the INIT_DONE output. Cheers, Dave
