19 years ago
Cyclone III AS configuration bizarreness
I am using a cyclone III (EP3C25F324C8N) with an EPCS16 configuration device.
I am programming the configuration device through the FPGA with the serial flash loader.
The problem is that the Cyclone III device will not configure itself from the EPCS16. It is stuck in an endless loop of retries UNTIL I MOMENTARILY SHORT THE nSTATUS PIN TO 3.3 VOLTS!!!! (...I discovered this by accident, no grounding the pin doesn't do it.)
As soon as I do that the device configures and runs my test program (blinks LEDs). I also tried driving it high momentarily with an 8051 to no avail.
Any ideas?
Rob
UPDATE: It also configured when I touched CONF_DONE with a probe. Upon further investigation I found that adding a 100 pF capacitor from CONF_DONE to GND fixes this problem ...no idea why.
