19 years agoCyclone III AS configuration bizarreness
I am using a cyclone III (EP3C25F324C8N) with an EPCS16 configuration device. I am programming the configuration device through the FPGA with the serial flash loader. The problem is that the Cyc...
18 years agoHi Folks,
I am seeing correct AS (.pof) and JTAG (.sof) configuration of my EPCS128 and EP3C16 devices respectivly. However .JIC configuration fails to fire up the system. The Altera programmer reports that all is well, but the Config-done pin is never released. I have filed an SR with Altera as I suspect the .JIC is not being generated correctly.
