17 years agoCyclone III and SDR SDRAM
Hi, I want to connect SDR SDRAM to Cyclone III, but I'm a little confused about voltage levels(LVTLL 3.3V). I've read http://www.altera.com/literature/an/an447.pdf but I'm not sure I understan...
16 years agoHi,
I found that 3C25 standard nios II example really got problem. when i run a simple hello world example from NIOS II template, it has the error where verify address failed at the address pointing to the sdram. anyone has the same issue? caridee
