9 years agoCyclone III and 2xSDRAM
I need to open topic because I couldn't find answers anywhere so maybe someone can help. Card is designed around EP3C40F484C6N with 2 SDRAM chips IS42S16320B-6TL but they are connected on opposite...
9 years agoThe 14 mm difference in trace lengths only amounts to about 100 ps skew, this would only be of impact at the higher frequencies.
There are a few other unknowns: Do you use 1 or 2 controllers? Do you use Altera IP, Third Party IP, or did you write your own? What is your target operating frequency? The full 166 MHz?
