14 years agoCyclone III Active Serial Configuration
Does anyone know how long it will take to configure a EP3C10 with a EPCS1 using the active serial (AS) configuration? I need the FPGA to be live around 300 ms after power-up, and wanted to know if t...
14 years ago --- Quote Start --- You need to take into account the POR time (you'll probably have to use a fast POR, but then, be sure that your power supplies will reach the correct level in time), then you have the configuration itself (page 9-20 gives you a method to estimate the maximum configuration time) and finally the initialization (pages 9-9/9-10) before the FPGA goes into user mode. --- Quote End --- Why would you be concerned that the power supplies are at the correct levels? Won't the FPGA start the POR time (3ms-9ms for Fast POR) once the power supplies have reached their correct levels?
