17 years agoCyclone III-120: M9K read, write failure
Hi, In our design I have a custom memory controller connected to the Avalon MM bus, with one Avalon MM interface, and at the other side of the controller I have four instantiations of 512x32b memo...
17 years agoHi
I have changed the memory structure from three memory block behind on Avalon MM interface to one larger memory block. After changing the memory controller I did some tests with succes. It works, but still can not find any good reason why the previous design didn't work correctly. As I said, I measure the same timing diagrams on three memory blocks, but one refuse to remember what I a write. Bye Bert
