10 years agoCyclone III + EPCS4 + UART remote upgrade
Hi ALL, I have a custom logic design in a Cyclone III FPGA (EP3C10). The configuration is stored in a EPCS4 configuration device and I am using AS scheme to configure the FPGA at factory. Also, there...
10 years agoWhat kind interface does your device use in the field to talk with the outside world?
1). Nios II processor with sufficient memory to run a command processor to accept commands from the outside world 2). Interface to take commands from outside world. 3). Remote Update Controller (Cyclone III) ==> Used to reconfigure the FPGA after the update 4). EPCS Flash Controller ==> This contains a SPI controller you can access directly using a 0x400 base offset and the epcs_commands.h and altera_avalon_spi.h, or via the HAL (altera_avalon_epcs_flash_controller.h)
