17 years agoCyclone ii, VCCIO 2.5V and 3.3V input
Hello everybody, is it possible to connect 3.3V to an input located in a bank configured to VCCIO 2.5V without e.g. an external resistor for voltage translation? Is the input 3.3V tollerant in...
17 years ago --- Quote Start --- I/O standard 2.5V in the said table and elsewhere means mainly VCCIO of 2.5 V. It's not generally required to enable PCI clamp diodes when overdriving the input, but should be done, if you expect an overshooting input signal. --- Quote End --- Thanks for your answer FvM. Then my setting is fine :)
