19 years ago
Cyclone II programming problems
Hi all --
I've built a few PCBs based on Cyclone II FPGAs. Some of these boards, and especially the last, suffer from an annoying problem:
When connecting the FPGA to the JTAG cable, Quartus II detects and correctly identifies the Cyclone II. When I program the FPGA with a sof file, Quartus II shows me this:
Info: Started Programmer operation at Tue Jul 31 16:22:13 2007
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020B20DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Tue Jul 31 16:22:15 2007
Very nice. However, the program is not loaded on the FPGA! This can also be verified by the current drawn: when programming the CylconeII, the current consumed goes up by 10 mA, and afterwards it drops again.
At this moment, the FPGA is configured as in Figure 13-25 on page 13-63 of the CycloneII handbook, only the serial ram device has not been soldered on the board. Both MODE0 and MODE1 have been connected to ground. I'm using a USB blaster, running at 3.3V. Pullups are also conected to 3.3V. Only, I'm using 1.2kOhm resistors everywhere, I don't think this can be the cause?
With previous boards, after 10 programming attemps it worked and afer a week of FPGA usage, it worked from the first time. This latest design however does not load at all.
Any comments on this are much appreciated!
Riemer
