19 years agoCyclone II programming problems
Hi all -- I've built a few PCBs based on Cyclone II FPGAs. Some of these boards, and especially the last, suffer from an annoying problem: When connecting the FPGA to the JTAG cable, Quart...
18 years agoHi,
I'm able to solve (or maybe partially solve) the JTAG problem by enable the "Halt on-chip configuration controller" under Quartus II software. This option prevent AS reconfiguration loops from the blank series configuration device. I wonder isn't that the main cause of the problem as if not mistaken, JTAG configuration takes precedence over other configurations. Further more, my other 2 PCBs have not such symptom with that option turned off. And also, JTAG not working even with the absent of series configuration device, hence "Halt on-chip configuration controller" options should not applicable to it. Regards, Dennis
