19 years agoCyclone II programming problems
Hi all -- I've built a few PCBs based on Cyclone II FPGAs. Some of these boards, and especially the last, suffer from an annoying problem: When connecting the FPGA to the JTAG cable, Quart...
18 years agoHello Dennis,
thanks for mentioning the interesting option. I wasn't aware of it's existence, but also didn't experience yet similar problems. If the description given in the Quartus Handbook is correct, I wonder why the option has been almost hidden in options menu? --- Quote Start --- halt on-chip configuration controller Halts the on-chip auto-configuration controller of the FPGA device for AS configuration, or the configuration device for PS or Fast Passive Parallel (FPP) configuration to allow JTAG configuration through a download cable. If you want to configure your FPGA through JTAG while the FPGA MSEL pins are set to AS mode, you should halt the on-chip configuration controller if any of the following occurs: ● the active serial configuration device connected to your FPGA is blank ● the active serial configuration device is not present ● an error occurs during AS configuration prior to JTAG configuration quartus ii version 7.2 handbook --- Quote End --- Regards, Frank
