11 years agoCyclone II max current
I am working on an alarm clock for my semester project. I have 88 leds that i want to drive with the FPGA. I am using the DE1 development board for testing the code. My plan is to switch to the EP...
11 years agoRead the 'DC Guidelines' in on page 10-32 of the cyclone ii device handbook (http://www.altera.co.uk/literature/hb/cyc2/cyc2_cii51010.pdf). This discusses the maximum current per group of pins, depending in the side of the device they reside on.
However, I recommend you steer clear of running the FPGA continuously at these currents. Whilst, on paper, the Cyclone II device may be up to what you're considering (I've not done the numbers for your requirements), they're not really intended to drive large banks of LEDs. The LED driver route, as suggested by cronus10, is the way to solve this. Or, if you really don't like the idea controlling such a multi-channel LED driver, you could use a suitable constant current source, such as Infineon's bcr401r (http://www.infineon.com/dgdl/bcr401r.pdf?folderid=db3a30431400ef68011407a9cfc70181&fileid=db3a30431400ef68011407ab7ea10185). This will be simpler for the FPGA but vastly more complex for your additional PCB as you will need one of these LED drivers per LED. Use the FPGA for what it's good at - as the brains of your solution - not for driving the LEDs themselves. Cheers, Alex
