11 years agoCyclone II max current
I am working on an alarm clock for my semester project. I have 88 leds that i want to drive with the FPGA. I am using the DE1 development board for testing the code. My plan is to switch to the EP...
11 years agoYou could use an led driver IC. There are plenty of them out there which take a serial input with an internal shift register, and they usually have a serial out for daisy chaining. You can then have just one set resistor per ic to set the led current. Here's an example from ti, TLC5925IDBQR
You can also find some fancy ones that support blinking and dimming.
