14 years agoCyclone II Lock Up after 4 seconds
I have a Cyclone 2 EP2C5 design that will run for 5 seconds before the entire part freezes. Four out of five boards operated correctly after removing reset synchronization for the the 20MHz domain. H...
14 years ago --- Quote Start --- Why are using the DEV_CLR pin for the reset ? --- Quote End --- I understand, that DEV_CLR is used as a regular pin. I think, the problem is either hardware related, e.g. supply voltage drop, or must be searched in the logic design.
