9 years agoCyclone ii FPGA eeprom erasing
Hi, I'm using cyclone ii fpga dev board. I have done the active serial programming by changing the mode from JTAG to Active Serial Programming in Quartus ii software. It works fine, but when apply...
9 years agoCan you program the FPGA via JTAG? You should always be able to do this, regardless of the position of the RUN/PROG switch.
If you're concerned whether the board is broken try reprogramming the factory default image into the EPCS. It's available on the resource CD that comes with the board. Cheers, Alex
