9 years agoCyclone ii FPGA eeprom erasing
Hi, I'm using cyclone ii fpga dev board. I have done the active serial programming by changing the mode from JTAG to Active Serial Programming in Quartus ii software. It works fine, but when apply...
9 years agoYes, you should always be able to put something into the FPGA via JTAG.
The 7-segment display will only show something if the FPGA is programmed and working. Which Cyclone II dev board is it? Cheers, Alex
