9 years agoCyclone ii FPGA eeprom erasing
Hi, I'm using cyclone ii fpga dev board. I have done the active serial programming by changing the mode from JTAG to Active Serial Programming in Quartus ii software. It works fine, but when apply...
9 years agobut after erasing the flash, we should be able to flash another program into fpga in jtag mode, right?
it is stuck and there is nothing in the seven segment leds as well. I have done the AS programming by changing the mode from jtag to ASP mode and configuration switch from RUN to PROG.
