15 years agoCyclone II Configuration
Hello, We are designing a system using Cyclone II FPGA, to decide which FPGA configuration should be used, I was reading the document "Configuring Cyclone II Devices" (referred below ) htt...
15 years ago --- Quote Start --- Yes you can configure the FPGA and program the EPCS device with a USB blaster. --- Quote End --- Hello, Thank you very much, but is the same cable can be used in the design phase for both, downloading the FPGA configuration file as well as downloading/debugging the developed code in NIOS II IDE for Eclipse. Kind Regards
