15 years agoCyclone II Configuration
Hello, We are designing a system using Cyclone II FPGA, to decide which FPGA configuration should be used, I was reading the document "Configuring Cyclone II Devices" (referred below ) htt...
15 years agoHello,
Thank you very much for your help. We decided to use AS as a configuration scheme (beside the JTAG that will be used in the design process). We would like to confirm that the USBBlaster cable is the only cable required in this situation. Thanks in advance.
