8 years agoCyclone 5 mismatch between VCCPD and VCCIO
We created a custom board that has 5CSEBA4U19 chip. The VCCPD pins for all banks have 3.3V but VCCIO is 2.5 on some banks. The datasheet clearly states that I must set VCCPD to 3.3V when VCCIO ...
8 years ago --- Quote Start --- Won't the FPGA bank that has 2.5V VCCIO and is connected to the 3.3V EPCS get damaged because of this supply mismatch? --- Quote End --- No. Refer to table 2 in the "cyclone v device datasheet (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-v/cv_51002.pdf)". This specifies the maximum operating overshoot the device can sustain before damage occurs to the device. Note: nowhere in this table does it specify how any of the rails are powered - it's independent of that. If you're happy to assemble a board I'd suggest you will be able to do a lot with it. So, it will not be wasted. All that can be said about input/output voltages, pre-drive behaviour and drive strength is that your setup is not supported, therefore not documented. However, as I've already suggested, a lot, if not all, of your board should work. Cheers, Alex
