8 years agoCyclone 5 fpga is not booting from spi flash
Hi all, I am trying to boot cyclone 5 (5cgtfd7d5f27i7n) FPGA from QSPI FLASH (epcq128si16n) .I am doing following steps: 1. I compiled counter program for blinking LED in quartux2,assigned FPGA pins,...
8 years agoYou've stated that CONF_DONE (FPGA_CONFIG_DONE?) does go HIGH after booting from FLASH. Is that right? If this is the case the FPGA has booted successfully.
CONF_DONE (FPGA_CONFIG_DONE) going high after i programmed flash.Again if i power off and on than (FPGA_CONFIG_DONE) not going high ,it is low and nstaus is also toggling. Thanks & Regards DEEPAK
