11 years agoCyclone 5 - Remote update
Hi, I try to implement a Design with remote update feature. Cyclone 5 EPCS64 Active Serial If I program a jic file with two configuration images into the flash (USB-Blaster) an...
9 years agoHi,
I want to know if the alt_asmi IP can write the bitstream file to Configuration memory. In the document of ALTASMI_PARALLEL IP https://www.altera.com.cn/content/dam/altera-www/global/zh_cn/pdfs/literature/ug/mfug_asmi.pdf, the auther wrote that "You can use the ALTASMI_PARALLEL megafunction to access the general purpose memory portion of the EPCS devices". Thanks!
