11 years agoCyclone 5 - Remote update
Hi, I try to implement a Design with remote update feature. Cyclone 5 EPCS64 Active Serial If I program a jic file with two configuration images into the flash (USB-Blaster) an...
11 years agoYou can e.g. use the hexout file generated by Quartus. But there's a problem of altremote_update IP if you activate the CRC check ("check_app_pof") option. So I'm using the *.jic file with the header stripped.
