12 years agoCyclone 4 Jtag - with VHDL
Hi,:(Hi, Can any one explain or give an example how to connect to Altera inside JTAG to be able to read values myself? Thanks, Roee
12 years ago --- Quote Start --- I'm more confused now than when I replied to your initial post from which I thought you wanted to read/write registers within your design through jtag. I'm also uncertain what you mean by different vhdl codes? Do you mean that you would like to load different fpga images from your own program? If so you don't need the user jtag register or the altsource/probes. You should rather look into embedded programming using svf or stapl. If your goal is simply to have a dialog box to choose which fpga image to load you could simply fork out a small shell to run quartus_pgm from within your program. Assuming this is running on a x86 pc. --- Quote End --- Hi, Did overcome most of my problems with help. Now some more questions please: I have a code (VHDL) - that I can send JTAG commands - and see them in 7 segment on board (and leds) But for this I need to use quartus_stp (signal tap program) and CYGWIN program, Can I send the commands directly (though FTDI.DLL) - without using quartus_stp program and CYGWIN program, Or by using general windows command prompt instead Thanks, Roee
