17 years ago
Cyclone 3 I2C
I had a question about I2C on the Cyclone III. I have a design that uses some constants I would like to be able to change from a PC in real time. Is it possible to issue commands over the I2C bus that change internal RAM on the FPGA? Or is there a better way to do what I'm trying to do.
Andrew
    ok so you do have I2C access from a PC, cool. i've used both I2C and UART in the microcontroller world but only UART in FPGA. i haven't looked at the logic usage between the two protocols but i think that UART is simpler which is why i suggested it, along with most PCs being able to interface with it. you should be able to use I2C for your application.
    Well, the interface to the PC is actually through a USB controller (separate IC) and the USB controller has an I2C master on it that could talk to the FPGA. The USB controller also has UART so I suppose I could try that. Seemed like overkill to change like 16 bits of data though. Would I2C not work for this?
    Andrew
    hi andrew,
    how will you be interfacing I2C to your PC?
    can you switch your design to use a UART rather than I2C? most computers have a serial port or can have one with a cheap USB interface. you could then issue commands from a serial terminal on your PC to your CIII.
    on the FPGA you could use a UART core or you could use NIOS and include a UART. if you use a UART core you'll need to write some HDL to interpret the incoming data, if you use NIOS you could write C to do the same thing.
