17 years agoCyclone 3 I2C
Hi, I had a question about I2C on the Cyclone III. I have a design that uses some constants I would like to be able to change from a PC in real time. Is it possible to issue commands over the...
17 years agoWell, the interface to the PC is actually through a USB controller (separate IC) and the USB controller has an I2C master on it that could talk to the FPGA. The USB controller also has UART so I suppose I could try that. Seemed like overkill to change like 16 bits of data though. Would I2C not work for this?
Thanks, Andrew
