17 years agoCyclone 3 I2C
Hi, I had a question about I2C on the Cyclone III. I have a design that uses some constants I would like to be able to change from a PC in real time. Is it possible to issue commands over the...
17 years agohi andrew,
how will you be interfacing I2C to your PC? can you switch your design to use a UART rather than I2C? most computers have a serial port or can have one with a cheap USB interface. you could then issue commands from a serial terminal on your PC to your CIII. on the FPGA you could use a UART core or you could use NIOS and include a UART. if you use a UART core you'll need to write some HDL to interpret the incoming data, if you use NIOS you could write C to do the same thing.
