11 years agoCyclone 3 does not configure
EP3C10E144 EPCS16 MSEL=010 I designed board using circuit diagram on fig. 9-29. Performed AS programming, verified. Successful. But device is dead. Its nSTATUS is low. Voltage: VCCIO=3.31V, ...
11 years agoYes, it's a pain when hand working the boards. What we do is either solder paste it, and heat the bare board up on a hotplate with just the fpga until the paste flows, or pre tinning the board pad, then the chip pad and doing the same trick with the hotplate and a hot air gun until it flows.
Works ok with lead solder but is a royal pain with ROHS solder. (Much more likely to thermally damage the part) Another option I guess would be to use an electrically conductive epoxy like http://www.mgchemicals.com/products/adhesives/electrically-conductive/silver-conductive-epoxy-8331/. (Although I haven't tried that) Note: Arctic Silver 5 won't work. It's thermally conductive but not electrically conductive even though it has "Silver" in the name. Pete
