12 years agocyclone 3 and odd pin behavior
Using EP3C40F324I7N andEPCS16 in 'jic' setup. 'appears' only one pin, outputting a clock, D7, when programmed by the EPCS16, outputs a 'high' instead of a clock. (as apposed to low for un-assigned pi...
12 years agoso i tried changing the pin to reserve input. It still shows high output, but haven't test it to see if it is actually 'pulled' high, but, if i load 'sof' file, it drops to zero.
