12 years agocyclone 3 and odd pin behavior
Using EP3C40F324I7N andEPCS16 in 'jic' setup. 'appears' only one pin, outputting a clock, D7, when programmed by the EPCS16, outputs a 'high' instead of a clock. (as apposed to low for un-assigned pi...
12 years agoHow are your MSEL pins strapped? Are they configured for AS (Active Serial) configuration? You won't get a clock out of the FPGA's DCLK pin (to drive the EPCS) unless they are configured correctly.
In that device pin D7 is a general purpose I/O pin. You're not expecting it to be DCLK, are you? Regards, Alex
