CYCLONE 10GX remote temperature sensing
Thanks very much for reply. The TMP512 parameters are very similar to TMP451, including the default diode ideality factor. While going through the max 10 code we could not find any reference to changing it to Cyclone 10GX datasheet suggested 1.03.
While browsing other documentation I saw that Stratix datasheet actually suggests that for three current measurement method, some of the sensors should have ideality factor 1.006 while for two current method the 1.03 should be used.
Could you please confirm:
1) Do we understand correctly, that on the cyclone 10 Dev kit, the TMP512 default ideality factor used?
2) the Ideality factor in Cyclone 10 datasheet refers to two current measurement method and different value should be used for other measurements method?
(pasting the reference from stratix 10 datasheet)
