TR4
4 years agoCyclone 10GX Fails to Configure after multiple cycles
We assert nConfig to cause the FPGA to reload (for 1 second). After several attempts, the FPGA continually asserts nStatus, and is not visible on JTAG. The prevalence of this seems to change between ...
JohnT_Altera
4 years agoHi,
Are you performing Active Serial Programming? If yes, then I suspect that it is stuck in Active Serial Programming where it is not releasing the JTAG configuration mode.
