Cyclone 10 power-up latches up
As far from my concern, I am not aware of any registers within the JTAG part of the chip that can be read before the configuration happened.
How about the conf_done signal? Is it high or not after the nstatus remain low? Can you share the snapshot of the signals?
Aqid
once again thank you for your time and interest in my problem.
The conf_done line also remains low. In fact I think all the pins of the chip (except for the power pins of course) appear to be low and sinking current which is why I thought it might be some kind of problem with the chip latching up during power-up.
I have added an image that shows the rise of the 3 power rails at power up:
Orange is 3V3
Blue is 2V5
Purple is 1V2
Do they look ok to you?
I think I read something about "if an IO pin has a high signal on it, before power is applied to the chip this may cause a latch-up". Do you know if this is correct?
Many of the IO pins of the FPGA are connected to other devices in the design and I have not checked all pins to ensure that the above does not happen. The 3 power lines for the FPGA are themselves derived from a 5V PSU and it is possible that other devices which power directly from this 5V (although with 3V3 IO) may "come up" faster than the FPGA's own power lines.
Should I be concerned for this?
Kind regards
PhilipJ
- GLees3 years ago
Contributor
I had a similar-sounding problem with the MAX10 which has a known bug; some outputs are driven during configuration. The work-around was to check the box labelled "Enable real-time ISP to allow background programming when available" in the programming tool. Maybe this will work for you.
