JanVrkoslav
4 years agoCyclone 10 LP JTAG galvanic isolation
Cyclone 10 design guideline says:
JTAG pins in the Intel Cyclone 10 LP device are powered up by VCCIO. However, you may need to use VCCA in some cases. • For devices using VCCIO of 2.5, ...
YuanLi_S_Intel
4 years agoHi Jan
It is recommended value from the datasheet. You can try with the other voltage with level shifter. However, user need to take the risk from using that.
