JanVrkoslav
4 years agoCyclone 10 LP JTAG galvanic isolation
Cyclone 10 design guideline says:
JTAG pins in the Intel Cyclone 10 LP device are powered up by VCCIO. However, you may need to use VCCA in some cases. • For devices using VCCIO of 2.5, ...
FvM
4 years agoYour JTAG interface signals are sourced on board, thus it's quite simple to avoid overshoot that might violate input voltage range. I would add source side series termination with trace impedance (e.g. 50 to 70 ohm, including driver impedance).
Frank
