cyclone 10 LP evaluation Kit を使っています。 ARDUINO_ANAに入力されたアナログ信号値は "0x5E"のアドレスに格納されるとのことですが,アクセス方法がわかりません。教えてください。
- JonWay_altera
Hi @kkama7 I am not the expert in I2C, but i suppose you will need I2C controller IP in order to read access 0x5E.
I would presume you will need to follow the flow as in
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf#page=186 (Figure 54)
- kkama7
Thank you for your reply.
Although C10LP does not accept the analog input, C10LP-EV kit supports it via I2C communication from the max 10 device on the board.
The address "0x5E" is the register-address of I2C for the ADC of the max 10 device.
If you know samples about using I2C on C10 LP or LP-EV kit and tell me about them, I will be grateful.
Thank you.
- JonWay_altera
Hi @kkama7 , I am not sure I understand the problem statement. Firstly, C10LP does not support analog input, and secondly what/where is 0x5E?
