AJone5
6 years agoCyclone 10 LP AS Configuration Problems
I am having problems with a Cyclone 10 LP running a Nios processor that is writing spurious data to its configuration device on power down. I'm using a 16Mbit SPI configuration device and the EPCQ C...
ShafiqY_Intel
6 years agoHi AJone5,
Which Dual-purpose pins you set as Compiler Configured? (i.e DCLK pins or Data [7..2] pin or etc2)
When you set Dual Use pins option to Compiler Configured the DCLK stops, did the spurious data still written to configuration device on power down?
