AJone5
6 years agoCyclone 10 LP AS Configuration Problems
I am having problems with a Cyclone 10 LP running a Nios processor that is writing spurious data to its configuration device on power down. I'm using a 16Mbit SPI configuration device and the EPCQ C...
AJone5
6 years agoHi Wolfgang
I'm using a EPCQ16 type device and it is on our own designed PCB.
I'm using Quartus 18.1 if that helps.
I have found that if I set the Dual Use pins option to Compiler Configured the DCLK stops but if I set the same pins to regular IO then the DCLK continues after configuration.
I will try your suggestion about the Quad SPI Controller - thanks
