Zian
3 years agoCyclone 10 LP 10CL025 to 10CL006 migration
Hi ! I'm creating a PCB layout with a 10CL025 U256, and I'm wondering what will happen if I use in the future a 10CL006 U256 instead of this 10CL025 with the same PCB layout : - This migration mean...
FvM
3 years agoHi,
if you select migration devices in Quartus device configuration, the pins that are optionally connected to VCCINT or GND won't be available for any assignment, also not tristate. You can be pretty sure that Quartus configures the pins as necessary.
The previous questions about possible "abnormal behavior" are redundant as well.
- Zian3 years ago
I've tried : the report of migration tells that those pins are set as "input tristated".
So without setting migration, I can also set those pins to "input tristated".
