Cyclone 10 GX Startup Time Support
I have been utilizing Cyclone 10 GX (10CX105YF672E6G) FPGA for some time but now I require the FPGA to startup and run as fast as possible, I know there is a hard limit caused by flash communications or power sequencing, but I would like to know if there is anyway I could cut the startup time further, each 1ms would cause a difference, so if there are any documented or undocumented workarounds or tricks that could support this it would be fantastic.
Here are some recommendation to minimize the bootup time.
1- use fast flash - ASx4 or FPPx8 Flash is fastest
2- compress bitstream - can reduce up to 60% of original bitstream size
3- increase flash clock frequency - 100 to 166MHz if possible
4- optimize power ramp up time - VCC/VCCPT/VCCA can go as fast as 1-2ms(normal 5-10ms) while still meeting the spec
5- use Fast POR mode
regards,
Farabi
1 Reply
- Farabi_Altera
regards,
Farabi
